[solved] Create a custom linetype ('line with spikes')
edith88
Post by edith88 » Thu Feb 06, 2025 7:27 pm
Hello everyone!
Win 10, Qcad Pro 3.21.3.
I would like to create a custom linetype, but I don't have any experience in that.
The linetype I need (image on the right) is similar to the line named 'Tracks' (image on the left). I tried to change the linetype definition in the .lin file followed the description I found in the 'Additional linetypes' topic, but it doesn't look like as it should. I managed to change the length of the 'spikes' (1 mm) and the distance between them (10 mm). The problem is that the 'main line' always goes through the 'spikes', but the 'spikes' should start on the line (as the right image shows it).
Is there any way to do that or is there any other way in the program to create this line?
I also created a linetype that only contains 'spikes' and I tried to adapt it onto a simple line, but it doesn't fit perfectly.
At the moment, I can only add the 'spikes' one by one and I also must set the angles of them which takes all my time.
Thank you for your help in advance!
Re: Create a custom linetype ('line with spikes')
Post by Husky » Thu Feb 06, 2025 7:54 pm
you may check out the tool: Paste along Entity
https://qcad.org/doc/qcad/latest/refere ... ty_en.html
Keep an eye on the option bar to get what you are looking for...
edith88
Post by edith88 » Thu Feb 06, 2025 10:00 pm
Thank you very much!!! This is exactly what I was looking for and I would have never found out on my own. :D
Re: [solved] Create a custom linetype ('line with spikes')
Post by CVH » Fri Feb 07, 2025 1:15 am
The crossing segment of 'Tracks' Linetype is based on a shape stored in ltypeshp.cxf
That is a polyline with 3 vertices: (0,-1); (0,1); (0,1)
Already a question why it is a polyline with 2 identical vertices.
Indeed, the center of this is located at (0,0) ... In the middle.
'Track' is then symmetrical in regards with the base line.
For a segment at the right of your line the shape should be located completely under Y=0.
For a segment at the left, completely above Y=0.
One can edit ltypeshp.cxf with QCAD and add additional shapes to use in a Linetype definition.
Linetypes are always of the type A, Auto centered.
Meaning that the first and last occurrence are dynamically arranged so that the remaining space is distributed.
Complex Linetypes are not rendered in the 'Screen-based Linetypes' mode.
Another option would be FlexPainter (FP) using the OrthogonalMark painter.
Sometimes better controllable parameters and more options than PE.
edith88
Post by edith88 » Thu Feb 27, 2025 8:35 am
Thanks for the information. :)
Post by CVH » Thu Feb 27, 2025 8:39 am
Follow up: Redundant data in ltypeshp.cxf
And fixed meanwhile. :wink:
Post by CVH » Fri Feb 28, 2025 10:06 am
Got a report that this is misleading.
Indeed, this standard CXF is overwitten on each update of the QCAD application.
Instead, create your own custom CXF file based on the standard version and refer to that in a custom Linetype definition.
