Hi Andrew,
1/
When will QCAD 3 prof 2010 be released?
We are encountering more and more difficulty dropping new dwg back to the old DXF2000 format (using ACME cad convert) and maybe DXF2007 may help fix this.
Infact so bad we have being using acad to plot to HPGL and then using hpgl-dxf convertor to ensure they come into qcad exactly like intended.
2/
Will QCAD3 help the rendering of large DXF. We have some small DWG say 500k that become bloated (say 5mb as dxf). Qcad can take literally 2-3mins to load and render.... even though the machine continues happily on other apps (Qcad isn't using the machines full resources.)
If you want a really bad dwg+DXF please let me know
Or is there anything else that can help.
Best Regards
James
Qcad 2010
