Whether command line supports identifying and exporting different layers?
dreamskyer
Post by dreamskyer » Tue Jun 10, 2025 12:35 pm
Problem:Whether command line supports identifying and exporting different layers?
Expected output: Export different BMP/PNG files for each layer.
Environment
Linux Centos7
Qcad 3.23.3
A.dwg
(7.66 MiB) Downloaded 174 times
Expected output2.png (95.82 KiB) Viewed 15908 times
Expected output1.png (274.07 KiB) Viewed 15908 times
Re: Whether command line supports identifying and exporting different layers?
Post by andrew » Tue Jun 10, 2025 12:50 pm
You can use the -layer switch toi export only a set of given layers. Regular expressions are supported.
E.g.
-layer=A,B,X.*
to export layer A, layer B and all layers starting with X.
