External Reference
fridge
External Reference
Post by fridge » Mon May 28, 2007 9:00 am
As far as I can oversee, there is no possiblity to use external references. Am I wrong or is it possible through a workaround. The only way I can think of is to import the reference drawing as a block.
michael
Post by michael » Sat Sep 22, 2007 3:29 pm
"external references" Can you explain it in more detail. What is it exactly is it? Does it come from AutoCAD?
kasper
Post by kasper » Thu Sep 04, 2008 10:32 am
importing an external reference as a block is a good way to do it. Of course you will miss some functionality like acad has for xrefs. I use this sometimes and find it a good way to work with qcad. :wink:
