Script Shell (GE) fails for the simplest if-else clause
Post by CVH » Sat Sep 06, 2025 5:36 am
Related to a script code in this topic
This most simple if-else clause fails for GE but not as script file using 'Run Script' (XC):
var document = EAction.getDocument();
if (!isNull(document) && document.hasSelection()) {
    // Do something meaningful:
    EAction.handleUserInfo("Done something meaningful.");
else {
    // Warn user on critical faults:
    EAction.handleUserWarning("No document or no selection.");
A command string is concatenated until the count of all open brackets ( & { & [ equals the count of all closing brackets ) & } & ].
The above code is thus evaluated in 3 steps:
- eval("var document = EAction.getDocument();")
- eval("if (...) {...}")
- eval("else {...}") Resulting in a: Syntax error
In what other condition would else apply if evaluated apart from the if clause?
The code below doesn't fail:
if (1 > 0) {
    else {
Evaluated in two steps:
- eval("if (1>0) {...}")
The "if (1 > 0) {...}" fix does work when enclosing the specific 71 lines of code in the related topic.
But you can't stretch it indefinitely.
:arrow: Also remark that brackets in plain text or comments are accounted for just the same. :roll:
// This won't run because of the Sad smiley :(
else {
Not evaluated yet, the Shell expect more lines including one with the associated closing bracket of the smiley.
Add that bracket in a comment otherwise it results in a: Syntax error
Include brackets in plain text intended for a string using their character codes.
Another solution is to include your code as a block starting with '{' and ending with '}'
And yet another solution but much slower is defining the block as a function and calling this function.
function main() {
main();
The last 2 solutions rely on the fact that the block text or the function text is only evaluated after the last closing bracket.
Just the same as with the dummy "if (1>0) {...}" clause.
