qcad profile cut
1engravecut
qcad profile cut
Post by 1engravecut » Wed Jan 07, 2026 9:59 pm
i inside cut a square 2" x 2" i use bit 0.124" cut result is 2.124" x 2.124" i cut again same size square machine cuts out exact cut out again 2.124" x 2.124" what i am doing wrong? thank you
1engravecut
Re: qcad profile cut
Post by 1engravecut » Wed Jan 07, 2026 10:01 pm
sorry forgot to say in in 2nd cut i input different size cutter 0.622 bit
Post by CVH » Thu Jan 08, 2026 6:19 am
Sounds like a QCAD/CAM question. :wink:
You probably cut 'On path' and don't compensate the cutter diameter.
The CNC-driver follows the path with the cutter centered on the path.
Hence, it will be 1/2 cutter wider at one edge and another 1/2 diameter wider at the opposite edge.
To compensate we chose Left or Right of path and that according the milling method 'Conventional' or 'Climbing'
Compensation can be done in 2 ways.
- Or QCAD/CAM exports an offset path (G40).
- Or you use G41/42 and your CNC-driver does the rest.
For the latter QCAD/CAM exports the paths as they are.
Also check whether your driver is G41/42 capable, otherwise these instructions may be skipped.
And whether you use a post-processor intended for G41/42 or for a calculated offset.
A post-processor that exports a calculated offset typically has 'offset' in it description.
The 0.622" cutter size with the same result doesn't make any sense to me.
With offsetting to a path, calculated or G41/42, always use the programmed size cutter.
QCAD/CAM, nor your CNC-driver can verify the actual tool size. :wink:
