Suggestion for Dimension Location setting
Moderator
Post by Clive » Wed Nov 19, 2014 1:32 pm
When placing dimensions in drawings it would be easier and more useful to have an option in the Dimension settings dialogs to set an offset distance from the entity we are dimensioning - especially if we want quick uniform dimensioning on lots of objects throughout the entire draft.
So in my example below I could have set a required distance in the dimension settings dialog and QCAD would then dynamically set all my dimesion loaction offset distances accordingly 8).
Dimension Setting Request.png (29.23 KiB) Viewed 5743 times
Hope it makes sense to all :) .
