[SOLVED] Drawing a leader with arrow as default
massimo
Post by massimo » Tue Dec 02, 2014 5:59 pm
Hi, if I draw a leader (DE) it has always no arrows per default. How can I change this so I don't need to enable the arrows every time?
Best regards.
Community Version 3.28.2.0, Gentoo Linux on amd64
Re: Drawing a leader with arrow as default
Post by andrew » Tue Dec 02, 2014 6:21 pm
The tool should remember your last choice.
1. Dimension > Leader
2. Check the 'Arrow head' checkbox:
Screen Shot 2014-12-02 at 18.18.23.png (11.69 KiB) Viewed 6393 times
3. Draw leader
4. Right-click to end tool
5. Dimension > Leader
6. Arrow head check box should be checked.
If this is not the case, please let me know, so I can file a bug report. Please indicate your QCAD version and operating system in this case. Thanks.
massimo
Post by massimo » Tue Dec 02, 2014 9:16 pm
Thanks, I did not see the checkbox...
