Clip Bitmap Images
Keith Bellis
Clip Bitmap Images
Post by Keith Bellis » Thu Jan 22, 2015 5:28 pm
Hi
I am in the process of learning QCAD Pro after having previously used Autocad (too expensive) and Draftsight (doesn't function with Mac OS 10.10.1).
As expected there are some differences etc but I seem to be getting on OK except for being able to clip images...In Autocad & Draftsight I am able to clip a bitmap in order that only a part of the bitmap is displayed both on screen and in the final output drawing...my question is does QCAD offer a similar function (if so where?) and if not could this be incorporated in future releases :?:
Many thanks
Keith Bellis
Re: Clip Bitmap Images
Post by andrew » Thu Jan 22, 2015 5:32 pm
This is not supported by QCAD at this point.
I've added a feature request at:
http://www.qcad.org/bugtracker/index.ph ... &project=1
Keith Bellis
Post by Keith Bellis » Thu Jan 22, 2015 7:07 pm
Andrew
Much appreciated
Keith Bellis
