Suggestion of a qcad pro's user
Tuttle
Post by Tuttle » Tue Apr 07, 2015 12:46 pm
I hope that I don't write too much posts a few days.
I draw building plans, and in this business, we need many dxf drawings (cups, plan views ...), and often with much identical layers. When we modify a drawing (for example an outside wall), we have to change it for all the other drawings as well. This is hard work, and I wonder if it's possible to find a system to link a drawing to another (the blocks are often binding for that use), and so be able to pass a change to all the other drawings (and make it easier construction lines).
What do you think of the future evolution of qcad?
I hope to speak properly, my English is not very good (thank you Google!)
Thank you !
Debian Jessie - 64 bits KDE environnement
QCAD Pro 3.9.1.0
Qt Verison : 4.8.4
Compiler : gcc 4.4.3
Re: Suggestion of a qcad pro's user
Post by andrew » Thu May 07, 2015 10:30 am
