Arrangin elements
pierluigi76
Arrangin elements
Post by pierluigi76 » Wed May 28, 2008 5:25 pm
Is it possible in qcad to automatically align items or space them by some factors like distance between the center or snap points ?
Thanks in advance,
Pierluigi Longoni
Post by andrew » Wed May 28, 2008 8:47 pm
No.
If the items are identical, you can create an array of blocks or use the copy function with multiple copies to achieve that.
If the items are not identical, you would have to create an auxiliary construction.
