Intersecting Lines
tchiz
- Registered Member
Intersecting Lines
How do I draw intersecting lines that are not supposed to touch each other? As in a wire diagram, where two wires cross, but are not supposed to touch each other.
tchiz
- Registered Member
Intersecting Lines
It is about QCAD
Re: Intersecting Lines
OK - please post your question again in one of the QCad forums if you don't mind. This is a dxflib forum.tchiz wrote:It is about QCAD
You can find the overview over the forums here:
http://www.ribbonsoft.com/rsforum/
