Space doens't focus on command line (Linux mate)
renod
Space doens't focus anymore on command line (Linux mate).
What can I do?
Thank you. R.
What can I do?
Thank you. R.
- Clive
- Moderator
Re: Space doens't focus on command line (Linux mate)
Hi renod
Have you tried ?
Main menu > Edit > Application Preferences > Tool Settings - type and search 'Focus on command line' restore the default settings and click apply.
Let us know if this does the trick or not.
Have you tried ?
renod
Thanks Clive
I did restore the settings but without expected results.
Even CTRL-M doens't work.
But others shortcuts like CTRL-N works...
Version:
3.14.3.0 (3.14.3)
R.
Ps: Clive do you use a linux version? Because this problem is not new for me but I don't remenber after witch update this problem appears...
Version:
3.14.3.0 (3.14.3)
R.
- Clive
- Moderator
Bug report added;renod wrote: I did restore the settings but without expected results.
Version:
3.14.3.0 (3.14.3)
http://www.ribbonsoft.com/bugtracker/in ... sk_id=1451
I use QCAD on Windows 10 and Linux Mint. I haven't experienced this problem on either operating systems.renod wrote:Ps: Clive do you use a linux version? Because this problem is not new for me but I don't remenber after witch update this problem appears.
Unfortunately, this problem cannot be reproduced here on any Linux system, including Ubuntu Linux with the Mate desktop (32bit or 64bit).
If you can submit additional information that might help to identify or reproduce the problem, please re-open the above task in the task tracker.
You might also want to try resetting your configuration (delete file ~/.config/QCAD/QCAD3.conf).
renod
Oki I got it.
The "space" shortcut focus on the command line only if the widget "command line" is not detached from the main window.
Thanks a lot for helping me to find a solution.
P.S. I did not try to reopen the bug because I don't use the latest version.
Reno.
Reno.
- Clive
- Moderator
I see, I think that even if the command line is un-docked, you should still be able to focus on it by hitting the space bar. After testing I find that if I start a new drawing and the first thing i do is hit the space bar in an un-docked command line the focus goes there, but after that it doesn't work!renod wrote:The "space" shortcut focus on the command line only if the widget "command line" is not detached from the main window.
I think you've found a bug
renod
Hi Clive,
Since 20 years I'am using free software only (except some rare exceptions) and it's the first bug that I have discovered before another one did it
Reno.
Reno.
Thanks for the update.
Can you overwrite your file scripts/View/CommandLineFocus/CommandLineFocus.js with this file:
https://raw.githubusercontent.com/qcad/ ... neFocus.js
Please let me know if that fixes the problem on your system, thanks.
- Clive
- Moderator
For me, it works just fine now on Linux Mintandrew wrote:Please let me know if that fixes the problem on your system, thanks.
@ Reno, let us know if this fix works for you too.
- Clive
- Moderator
Update:
Works on Windows too, just fine.
renod
Just fine too
Linux 4.3.0-0.bpo.1-amd64 #1 SMP Debian 4.3.5-1~bpo8+1 (2016-02-23) x86_64 GNU/Linux
Mate.
Version Qcad-pro:
3.14.3.0 (3.14.3)
Reno.
Mate.
Version Qcad-pro:
3.14.3.0 (3.14.3)
Reno.
- Clive
- Moderator
Reno
Thank you for reporting back , very glad to hear it works for you too.
