[solved] Dashed and dotted lines on different layers
Patry0t
Hello everyone!
I would like to ask, how can I draw a dashed (--- --- --- ---) and a dashdot (--- - --- - --- - ---) line with dxflib? Also I would like to draw them to different layers: continuous lines to layer '0', dashed line to layer 'd', and dashdot line to layer 'dd' .
I read the documentation but maybe I'm too tired and missing something, could someone help with this?
Patry0t
Patry0t
Re: Dashed and dotted lines on different layers
You'd typically call writeLinetype between tableLinetypes and tableEnd. Then you can use the linetype name for example for a layer (writeLayer).
Patry0t
thank you for your quick reply.
I tried something like this:
Then I would like to draw the line according to my linetypes in LineT (111 filled, 222 dashed, 333 dashdot).
But this not seem to work :\
dw->tableLinetypes(3);
dxf->writeLinetype(*dw, DL_LinetypeData("BYBLOCK", "BYBLOCK", 0, 0, 0.0));
dxf->writeLinetype(*dw, DL_LinetypeData("BYLAYER", "BYLAYER", 0, 0, 0.0));
dxf->writeLinetype(*dw, DL_LinetypeData("CONTINUOUS", "Filled", 0, 0, 0.0));
/*dxf->writeLinetype(*dw, DL_LinetypeData("CONTINUOUS", "Dashed", 1, 0, 0.0));
dxf->writeLinetype(*dw, DL_LinetypeData("CONTINUOUS", "Dashdot", 2, 0, 0.0));*/
dw->tableEnd();
int numberOfLayers = 3;
dw->tableLayers(numberOfLayers);
dxf->writeLayer(*dw,
DL_LayerData("0", 0),
DL_Attributes(
std::string(""), // leave empty
DL_Codes::black, // default color
100, // default width
"CONTINUOUS", 1.0)); // default line style
DL_LayerData("d", 0),
DL_Attributes(
DL_LayerData("dd", 0),
DL_Attributes(
dw->tableEnd();Code: Select all
dw->sectionEntities();
// write all entities in model space:
for (int i = 0; i < line_endpoints.size(); i++) {
if (lineT[i] == 111) {
dxf->writeLine(
*dw,
DL_LineData(line_endpoints[i][0], // start point
line_endpoints[i][1],
0.0,
line_endpoints[i][2], // end point
line_endpoints[i][3],
0.0),
DL_Attributes("0", 256, -1, "BYLAYER", 1.0));
else if (lineT[i] == 222) {
dxf->writeLine(
*dw,
0.0,
0.0),
DL_Attributes("d", 256, -1, "BYLAYER", 1.0));
else {
dxf->writeLine(
*dw,
0.0,
0.0),
DL_Attributes("dd", 256, -1, "BYLAYER", 1.0));
dw->sectionEnd();- andrew
You have two linetypes named "CONTINUOUS".
All of your layers use linetype "CONTINUOUS".
Also, you are not actually defining any dashed patterns in the DL_LinetypeData constructors.
Patry0t
yes, I tried something like this:
But that gives me compile error, because the argument list of LinetypeData is not matched. When I give one less argument it also stops working.
Is it something with the versions? I use AC1015 version just like in the documentation, I dont get it.. I just want to use the version that matches the documentation on your website here, but that gives me compile error.
dw->tableLinetypes(5);
dxf->writeLinetype(*dw, DL_LinetypeData("DASHED", "Dashed", 0, 10, 3, 0.111000111));
dxf->writeLinetype(*dw, DL_LinetypeData("DASHDOT", "Dashdot", 0, 10, 5, 0.111010111));
dw->tableEnd();Is it something with the versions? I use AC1015 version just like in the documentation, I dont get it.. I just want to use the version that matches the documentation on your website here, but that gives me compile error.
The last parameter of the DL_LinetypeData constructor is an array of doubles with the desired dash lengths (positive) and gap lengths (negative), e.g.
double dashes[2] = { 2.5, -0.5 };
For a dash of 2.5 Millimeter followed by a gap of 0.5 Millimeter, etc.
Patry0t
something like this? This compiles at least, thanks!
This compiles now, which is good, but than I still have only continuous lines when I open it in AutoCAD :\
dxf.writeLinetype(*dw, DL_LinetypeData("BYBLOCK", "BYBLOCK", 0, 0, 0.0));
dxf.writeLinetype(*dw, DL_LinetypeData("BYLAYER", "BYLAYER", 0, 0, 0.0));
dxf.writeLinetype(*dw, DL_LinetypeData("CONTINUOUS", "Filled", 0, 0, 0.0));
dxf.writeLinetype(*dw, DL_LinetypeData("DASHED", "Dashed", 0, 10, 10, dashes));
dxf.writeLinetype(*dw, DL_LinetypeData("DASHDOT", "Dashdot", 0, 10, 10, dashes));
dw->tableEnd();-
Patry0t
any idea why?
Did you also pass those linetype names to writeLayer (can you post your adjusted code)?
Patry0t
double dashdot[2] = { 5.0, -0.5 };
dxf.writeLinetype(*dw, DL_LinetypeData("DASHED", "Dashed", 0, 10, 5, dashes));
dxf.writeLinetype(*dw, DL_LinetypeData("DASHDOT", "Dashdot", 0, 10, 5, dashdot));
dw->tableEnd();
dxf.writeLayer(*dw,
DL_Attributes(
dxf.writeLayer(*dw,
DL_Attributes(
DL_Codes::red, // default color
"DASHED", 1.0)); // default line style
dxf.writeLayer(*dw,
DL_Attributes(
DL_Codes::blue, // default color
"DASHDOT", 1.0)); // default line style
dw->tableEnd();
dw->tableStyle(1);
dxf.writeStyle(*dw, DL_StyleData("standard", 0, 2.5, 1.0, 0.0, 0, 2.5, "txt", ""));
dw->tableEnd();
dxf.writeView(*dw);
dxf.writeUcs(*dw);
dw->tableAppid(1);
dxf.writeAppid(*dw, "ACAD");
dw->tableEnd();
dxf.writeDimStyle(*dw, 1, 1, 1, 1, 1);
//FOR
//minden egyenesre egy blokk
dxf.writeBlockRecord(*dw);
dxf.writeBlockRecord(*dw, "myblock1");
dw->tableEnd();
dw->sectionEnd();
dw->sectionBlocks();
dxf.writeBlock(*dw, DL_BlockData("*Model_Space", 0, 0.0, 0.0, 0.0));
dxf.writeEndBlock(*dw, "*Model_Space");
dxf.writeBlock(*dw, DL_BlockData("*Paper_Space", 0, 0.0, 0.0, 0.0));
dxf.writeEndBlock(*dw, "*Paper_Space");
dxf.writeBlock(*dw, DL_BlockData("*Paper_Space0", 0, 0.0, 0.0, 0.0));
dxf.writeEndBlock(*dw, "*Paper_Space0");
dxf.writeBlock(*dw, DL_BlockData("myblock1", 0, 0.0, 0.0, 0.0));
dxf.writeEndBlock(*dw, "myblock1");
dw->sectionEnd();
dxf.writeLine(
*dw,
0.0,
0.0),
dxf.writeLine(
*dw,
0.0,
0.0),
else {
dxf.writeLine(
*dw,
0.0,
0.0),
dw->sectionEnd();
But for some reason this prints out all the lines in continuous.
Could you please attach your DXF file written with the above code?
Patry0t
yes, sure but its now updated with circles and arcs too. But I changed nothing on the lines, so its still the problem with dashes and dashdot.
- myDxf.dxf
- (11.51 KiB) Downloaded 2348 times
If you look at the linetype definitions in the DXF file, you can see that there is a problem with the dash pattern definition:
0
LTYPE
5
31
100
AcDbSymbolTableRecord
100
AcDbLinetypeTableRecord
2
DASHED
70
0
3
Dashed
72
65
73
10
40
6.0
49
2.5 <-- dash: OK
74
0
49
-0.5 <-- gap: OK
74
0
49
-92559631349317830736831783200707727132248687965119994463780864.0 <-- NOT OK.
74
0
49
Reason: the number of dashes passed to the DL_LinetypeData constructor is wrong and so is the pattern length:
Should probably be:
DL_LinetypeData("DASHED", "Dashed", 0, 2, 3.0, dashes)
DL_LinetypeData("DASHDOT", "Dashdot", 0, 2, 5.5, dashdot)
0
LTYPE
5
31
100
100
2
DASHED
70
0
3
Dashed
72
65
73
10
40
6.0
49
2.5 <-- dash: OK
74
0
49
-0.5 <-- gap: OK
74
0
49
74
0
49
Should probably be:
Patry0t
Thank You, finally I understand it. You helped me a lot!
I could solve it like this:
double dashdot[4] = { 5.0, -0.25, 0.25, -0.25};
dxf.writeLinetype(*dw, DL_LinetypeData("DASHED", "Dashed", 0, 2, 3.0, dashes));
dxf.writeLinetype(*dw, DL_LinetypeData("DASHDOT", "Dashdot", 0, 4, 5.75, dashdot));
dw->tableEnd();
