dimension block and other blocks
Use this forum to ask questions about how to do things in dxflib.
wwinthan
Post by wwinthan » Tue Aug 19, 2008 8:22 pm
Do you know how to differentiate between the block that contains the dimension
and the block that doesn't contain the dimension?
cuz in m_block[0-20] some of them are dimension some are not
thanks
wwinthan
Post by wwinthan » Tue Aug 19, 2008 9:59 pm
I dont' know where the extrusion for Circle is stored in dxflibobject?
i don't know the author doesn't mention about it. it's hard to use his code without him writing a enough documentation.
wwinthan
can't find direction for each entities in dxf object
Post by wwinthan » Tue Aug 19, 2008 10:00 pm
I can find those extrusion(direction) factor in dxf file but i can't find in DXFlib object..
Return to “dxflib 'How Do I' Questions”
