Auto Trim
Auto Trim
Post by Husky » Wed Jul 19, 2017 7:40 pm
I remember that the Auto Trim function was at some point working pretty good for me. But since a while I'm struggling with this tool and I'm not sure why. Maybe somebody can tell me what is going on:
My idea how it has to work is the same what I can find in the tool description.
Auto Trim / Description: Trims or extends an entity on both sides to the next limiting entities.
Important is that it has to trims TO THE NEXT LIMITING ENTITIES. But it don't ...
I know ellipses etc are difficult but simple lines should work flawless.
Here a simple example. Depending on which line I click it works or not. Occasionally it works if I click two times the same point but that makes no sense to me.
Is it me or has something changed?
Auto Trim.dxf
(117.74 KiB) Downloaded 827 times
TSG
Re: Auto Trim
Post by TSG » Thu Jul 20, 2017 11:16 am
Similar problem here.
Sometimes it helps to click twice (not a dobbleclick but 2 slow clicks) on the specific line.
The result is better but not flawless.
I thinks Andrew should look at this.
regards Thomas
PS: the result also depends on where you click on the line. So you may try out different positions.
Re: Auto Trim
Post by andrew » Fri Jul 21, 2017 2:50 pm
Re: Auto Trim
Post by Husky » Sat Aug 19, 2017 9:15 am
It looks like it's fixed and available with the next update.
https://www.qcad.org/en/changelog
