Delete or detect overlapping line segment
aland
Post by aland » Thu Oct 05, 2017 8:41 pm
Is there a way to detect or delete a line segment which exactly overlaps with a longer line
Alan
Re: Delete or detect overlapping line segment
Post by Husky » Thu Oct 05, 2017 8:48 pm
Yes,
press and hold on your Keyboard the "alt" key and click with the left mouse button on the suspect entity.
aland
Post by aland » Thu Oct 05, 2017 9:06 pm
Ok thanks that seems to work -- but is there a way to do it on a selection of many lines without having to click on each one
Post by Husky » Thu Oct 05, 2017 9:21 pm
No.
The question is what is your goal? In the case that you are just looking for identical stacked entities then you could use "Detect duplicates" ...
aland
Post by aland » Thu Oct 05, 2017 9:28 pm
Detect duplicates only detects if the the 2 lines are exactly the same but I need to check a lot of lines that might partially overlap becuse of diferent lenghts etc.
hope that makes sense thanks for help
Post by Husky » Thu Oct 05, 2017 9:50 pm
Sounds like work ....
Maybe the "Selection Filter" is able to help you with this task.
abercet
Post by abercet » Mon Mar 05, 2018 9:30 pm
Hello
we need this toll to detect overlap segment.
it's crucial for dwg laser cutting.
This toll exist on laser drawing software.
Pleas make us a widgets quickly.
best regards
Post by andrew » Mon Mar 05, 2018 9:34 pm
