Dark Mode in macOS Mojave
TSG
Post by TSG » Fri Oct 12, 2018 11:35 am
I updated my macOS to 10.14 Mojave.
QCAD is still running well in "Light Mode".
But when I switch into the new "Dark Mode" text of the QCAD-UI is unreadable (i.e. white Text on white background).
Are there any plans to adapt QCAD to the Dark Mode of macOS Mojave?
Thomas
Re: Dark Mode in macOS Mojave
Post by andrew » Fri Oct 12, 2018 11:50 am
I cannot reproduce this problem here.
QCAD looks exactly the same in light or dark mode (apart from the menus).
Can you include steps to reproduce, screenshots, etc.?
Screen Shot 2018-10-12 at 11.56.01.png (497.49 KiB) Viewed 2252 times
TSG
Post by TSG » Fri Oct 12, 2018 3:19 pm
On my iMac the main window looks the same like yours.
But look at the layer-, block- or the other lists.
UNSELECTED text is white on white.
Thomas
Bildschirmfoto 1.jpg (15.32 KiB) Viewed 2245 times
Post by andrew » Fri Oct 12, 2018 3:28 pm
Strangely that's not the case here. Looks like it's trying to switch parts of the UI to dark on your system. Which exact package (DMG file name) did you install?
Screen Shot 2018-10-12 at 15.25.47.png (546.45 KiB) Viewed 2242 times
TSG
Post by TSG » Fri Oct 12, 2018 3:43 pm
Very strange indeed.
I'm using the QCAD release named qcad-3.21.3-pro-osx-10.10-10.13.dmg
Is there any newer release?
Thomas
TSG
Post by TSG » Fri Oct 12, 2018 3:53 pm
By the way: the starting dialog looks like this
Bildschirmfoto 2.jpg (44.03 KiB) Viewed 2240 times
Thomas
Post by andrew » Fri Oct 12, 2018 4:29 pm
No - same package here.
TSG
Post by TSG » Sat Oct 13, 2018 7:41 am
Hooray, I found a solution...
The problem is in macOS Mojave not in QCAD !!!
Maybe it helps some other Mac Users:
1. open the program TERMINAL
2. type in the following command:
defaults delete -g NSRequiresAquaSystemAppearance
3. restart your Mac
Now QCAD looks in Dark Mode like it has to look.
Thank you Andrew for your help to localize the problem.
Thomas
Post by andrew » Mon Oct 15, 2018 11:11 pm
Thanks for the info!
You can also opt out of dark mode for QCAD only in it's Info.plist file (QCAD-Pro.app/Contents/Info.plist):
Add these two lines to the bottom (before "</dict>"):
<key>NSRequiresAquaSystemAppearance</key>
<string>YES</string>
This will be added in the next release of QCAD (until Qt has some way of dealing with Dark mode properly).
