Search function in Reference manual
Shorelurker
Post by Shorelurker » Fri Nov 23, 2018 5:15 pm
Version: 3.21.2.1 (3.21.2)
Internet: QCAD.org
Build Date: Jul 10 2018
Revision: d3bf584
Qt Version: 5.8.0
Architecture: x86_64
Compiler:gcc 4.8.1
Ubuntu 16.04 LTS
So far everything I have tried to use works, however the search function in the reference manual returns the following:
Screenshot from 2018-11-23 16-08-17.png (104.86 KiB) Viewed 3979 times
the index is showing and the contents:
I feel a bit lost without it as I am not that familiar with the nomenclature.
Thanks for any help again
Screenshot from 2018-11-23 16-11-36.png (123.86 KiB) Viewed 3979 times
Re: Search function in Reference manual
Post by andrew » Tue Nov 27, 2018 11:24 pm
Thanks for the report. It looks indeed like under Linux the search tool does not work as well as on other systems. In particular, there's no stemming for the search terms which means that "arrow" will not find "arrows", etc.
Perhaps the (unofficial) single document PDF reference manual serves you better in this case:
https://qcad.org/doc/qcad/latest/refere ... ual_en.pdf
