https://www.qcad.org/rsforum/viewtopic.php?&t=2796
https://www.qcad.org/rsforum/viewtopic.php?&t=5411
among others...
A multi-offset is not a very good solution.
Meanwhile, I still use my build in CAM from my CNC driver.
Anyone can!
Download Eding cnc, the driver soft is free and runs in simulation mode (without an Eding board)
https://edingcnc.com/
https://edingcnc.com/download-software/
The soft is not very demanding and removed in a blink.
It's not a small player in the industry anymore.
You could configure the CNC part in respect with your machine.
The G-code will then be simulated correctly as well.
There is a 'Program' Tab that takes dxf files and makes *.cnc files with G-code.
It can Drill, Engrave, Pocket and Offset (in/out) with a bunch of other standard tricks.
However, this 'EasyCAM' section isn't updated anymore longtime and has some smaller hiccups.
Like Polys with NO pattern ... intricate pockets may have little 'defects' at some points for some settings ...
... a lower limit on the bulge of polys ...
A good prepared DXF and minor adjustments to the settings resolves that.
For the rest it works as a charm and is free (to try).
I can advice their driver boards over Linux, Mach and many others.
Maybe Andrew can contact Bert for the used libraries ???
						Pocket milling
				Jump to
	- General
- ↳ Announcements
- ↳ Chat
- ↳ Site Feedback
- ↳ Pre-sales Questions
- ↳ Introduce Yourself
- QCAD Professional Version
- ↳ QCAD 'How Do I' Questions
- ↳ QCAD Suggestions and Feedback
- ↳ QCAD Voting Corner
- ↳ QCAD Troubleshooting and Problems
- ↳ QCAD Installation and Upgrades
- ↳ QCAD Programming, Script Programming and Contributing
- ↳ QCAD 'Script Add-On & Plug-in challenge' - Work in Progress
- ↳ Finished 'Ready to go' Scripts/Plug-in's
- ↳ QCAD Tips and Tutorials
- ↳ QCAD/CAM
- ↳ What do you use QCAD/CAM for?
- QCAD Community Edition
- ↳ QCAD Community Edition
- International Forums
- ↳ Français
- ↳ QCAD Professional
- ↳ QCAD/CAM
- ↳ QCAD Community Edition (Version 3)
- ↳ Deutsch
- ↳ QCAD/CAM
- ↳ Italiano
- ↳ QCAD/CAM
- ↳ Español
- ↳ QCAD/CAM
- ↳ Português
- ↳ QCAD/CAM
- ↳ Nederlands
- ↳ QCAD/CAM
- QCAD Book
- ↳ QCAD - An Introduction to Computer-Aided Design
- ↳ QCAD - Una Introducción al Diseño Asistido por Ordenador
- ↳ QCAD - Eine Einführung in computerunterstütztes Zeichnen (CAD)
- QCAD Part Libraries
- ↳ General
- ↳ Creating DXF/DWG items
- ↳ Creating SVG items
- ↳ Meta Data
- dxflib
- ↳ dxflib Suggestions and Feedback
- ↳ dxflib 'How Do I' Questions
- ↳ dxflib Troubleshooting and Problems
