How to read lines width for DXF curves?
Use this forum to ask questions about how to do things in dxflib.
m_alexm
Post by m_alexm » Mon Apr 27, 2009 3:45 pm
I wanted to retrieve the lines width (Stroke dimension cf. Adobe Illustrator) for DXF curves, but I didn't succeed. Is it possible with dxflib library?
More details: I created a DXF file containing 2 curves with different line width (1 pixel and 2 pixels). When I read this file with dxflib library, I received 2 SPLINE objects with the following data (for both splines):
degree = 3
nKnots = 14
nControl = 10
flags = 8
Is there a way to retrieve the correct line width (Stroke dimension cf. Adobe Illustrator) for each curve.
Thank you,
Mihai
Post by andrew » Mon Apr 27, 2009 4:23 pm
In your addSpline(...) implementation:
int lineweight = attributes.getWidth();
Width or lineweight in DXF means:
-3 = Standard
-2 = ByLayer
-1 = ByBlock
0-211 = an integer representing 100th of mm
See also DXF reference at:
http://images.autodesk.com/adsk/files/acad_dxf0.pdf
m_alexm
Post by m_alexm » Tue Apr 28, 2009 4:20 pm
Thank you Andrew for your answer! It's working fine!
patricksnead24
Post by patricksnead24 » Fri Dec 04, 2009 1:36 pm
Hi All,
I can not get what is addSpline(...). can you explain it ?
Thanks,
:lol:
Post by andrew » Fri Dec 04, 2009 5:37 pm
addSpline is part of the dxflib interface DL_CreationInterface.
See examples in test/test_creationclass.cpp
addSpline works just like addLine, etc.
Return to “dxflib 'How Do I' Questions”
